dry nitrous system
will a 50 hp dry nitrous system work on a 92 3.1 v6
will the ecu put the needed fuel for it to work or are there something that needs to be done first any info will help |
Originally Posted by ncxmod355
(Post 544861)
Your set up will not add fuel with out being told to do so and thats kind of hard on a 3.1 ecu. However there is luck for your. For some reason the old iron 2.8 and 3.1 motors do like nitrous. You should be fine with a 50 dry shoot (should be) but why not play it safe and add a wet nozzle. You would also have the option to steep up to a bigger shoot in the future.
