Nitrous, Super Chargers, & Turbos All charged talk about going, and going FAST!
blow off valve help
Old Jul 2, 2010 | 12:14 AM
tejano24's Avatar
Default blow off valve help
Hello all
I’m new the forums but I had a few questions.
I have a 96 Z28 6 speed I put in a vortech supercharger a few years back. I have a little problem
I got a blow off valve, I wanted to have it to the atmosphere, I have a mass flow sensor and it makes my car run rich. I wouldn’t mind it, when I’m shifting but the valve opens with the vacuum line, when the car idles and I got black smoke coming out. So is there any type of blow off valve that does not have to have a vacuum line connected to it so the valve stays closed?
Thanks much any advice would be great.
Old Jul 2, 2010 | 10:38 AM
cbr600rx7's Avatar
You should not have black smoke at idle since it should only be venting when your building boost and then let off.
Old Jul 2, 2010 | 01:06 PM
tejano24's Avatar
thank you for your response.
the vacuum line holds the valve open. once i give it a little gas the valve closes. the line i am using has about 11 psi of vacuum and i guess its strong enough to pull the valve open, at a idle.
Old Jul 2, 2010 | 09:00 PM
cbr600rx7's Avatar
vacuum is not read in PSI.
they take a pressure/vacuum signal source. it senses the change in pressure/vacuum which opens a valve that diverts the air out through the chamber
The blow off valve is not open all the time just a brief second when the pressure change happens.
Old Jul 2, 2010 | 09:19 PM
cbr600rx7's Avatar
also your bov should be before your MAF so any air that would be lost would even mater since the maf isnt reading it too make the ECU run rich. It sounds like you may have a bad MAF or 02.
Both can cause you to run crazy rich.
Old Jul 3, 2010 | 03:49 PM
tejano24's Avatar
the vortech supercharger kit had me put the MAF before the supercharger right after the cone filter. so the air that is being let out is making my car run rich. i had a buddy look at it he said it was doing what bypass valve do. i have also tighten the spring and it still opens, would i be able to run it with no vacuum line?
Old Jul 4, 2010 | 09:46 AM
cbr600rx7's Avatar
I would relocate the MAF to where it should be (right before the TB) Other wise your not reading the correct air flow. I would strongly recommend a tune as well.
Old Jul 28, 2010 | 05:53 AM
sbc 98 comaro's Avatar
hey guys, i have a supercharged aussie car it runs no vac line!!!!
Position it closet to the fuel source throttle boddy, or card. It just releases unwanted boost when the throttle closses. So hence that is the best position.
Hope this helps, cheers ben.
Ecidemon
Sep 1, 2012 08:40 PM
bobshannon22
Feb 17, 2011 11:09 AM
ccrunner1104
Jul 2, 2010 10:09 PM
DLH
67-69 V8 Tech
Jan 13, 2009 01:50 PM
straightline81
82-92 V8 Tech
Feb 3, 2006 06:44 PM
