exsessive blow bye
Old Jan 13, 2009 | 12:30 AM
DLH's Avatar
DLH
Default exsessive blow bye
got a 67 with a 327 cant get ridd of the crankcase pressure. got the pvc valve, and valve breather, but still a lot of pressure[:@]
Old Jan 13, 2009 | 12:38 AM
Default RE: exsessive blow bye
The 67 has a special breather arrangement that goes into the block behind the intake manifold. Do you have that, or a valve cover breather?
What port do you have the other end of the PCV hose attached to?
Is your engine using/burning/drinking oil? Your piston rings could be shot, allowing too much pressure to get down into the crankcase.
Old Jan 13, 2009 | 12:41 AM
frostlime69's Avatar
Most likely the piston ring are worn out.
Old Jan 13, 2009 | 01:14 AM
DLH's Avatar
DLH
got valve breather, but behind the intake that hole is pluged off, anddrinking oil
Old Jan 13, 2009 | 09:15 AM
Ircyklops's Avatar
Crankcase pressure is exactly what it is, blow-by the rings. When the rings or cylinders are worn, you get blow-by. Which, in turn, causes crankcase pressure. Face it man there is no easy way ouy...RE-RING your engine. And you need to replace yyour downdraft tube.
Old Jan 13, 2009 | 01:50 PM
Saint_Ali's Avatar
ORIGINAL: frostlime69
x2...i agree
Ecidemon
Sep 1, 2012 08:40 PM
bobshannon22
Feb 17, 2011 11:09 AM
ccrunner1104
Jul 2, 2010 10:09 PM
murderd96z28
Mar 18, 2010 05:26 PM
straightline81
82-92 V8 Tech
Feb 3, 2006 06:44 PM
