1989 Iroc 5.0 dual cooling fans do not work
Old May 4, 2020 | 03:45 AM
kbrad1956's Avatar
Default 1989 Iroc 5.0 dual cooling fans do not work
New here , thanks for letting me in . I have a 1989 IROC , 5.0 , TPI , 5 speed manual . I was working on the A/C last week and noticed neither of the radiator cooling fans were working . The driver side fan comes on as soon as you start the car but shuts off immediately after starting whether the a/c is on or not .. The passenger side fan would not come on at all whether a/c is on or not . After doing a little research I found the cooling fan switch down between the number 6 and 8 spark plugs . I can unplug it and ground that wire and then both fans work with a/c on . According to things I read this means my wiring and the relays are good . If that is so where does that leave me ? All input appreciated . Thanks
kbrad1956
May 3, 2020 09:28 AM
baarf
82-92 V8 Tech
Oct 21, 2010 06:09 AM
SSV6
Jun 18, 2010 01:48 PM
sewerrat
Apr 23, 2009 11:22 AM
camaro girl
May 30, 2007 01:19 PM
