LT1/LT4 Tech 1993-1997
Z28 Died on me
Old Oct 26, 2009 | 10:10 PM
do u have a spare key? if so try it.
Old Oct 26, 2009 | 10:45 PM
doww301's Avatar
Default Scan
Sounds like you need to scan the car and see what codes (if any) it's throwing- I could be wrong, but I think that would be a good place to start.
Old Oct 26, 2009 | 10:54 PM
_Pirate_'s Avatar
I don't have any other spare keys. I did the nifty paperclip jumper to get into the diagnostics mode. It didn't show any codes.
Old Oct 26, 2009 | 11:04 PM
how did u get a paper clip to work in a 95. did it flash the 1 2?
Old Oct 26, 2009 | 11:21 PM
_Pirate_'s Avatar
It's the 16pin ALDL connector, pin 5 is the GRND and pin 6 is the SYS DIAG. The CEL light went away, and I was waiting for it to start flashing the code but it never did.
Old Oct 26, 2009 | 11:32 PM
well my wireing is different than yours so thats as far as i can go. there is a driver wire for the injectors that u need to check buut i cant tell u were it is. u have a different plugin for your ecm. the fuses for the injectors on mine are the #9 and 10 fuses in the box and are 7.5 amps. im thinkin it may be the key decoder modual. could be two bad injector driver wires that goes from the ecm and the injectors but thats unlikely. did u check an injector on each side?
Old Oct 26, 2009 | 11:35 PM
i dont think the paper clip thing works on your yr. as far as i know only on 93 and some 94s but dont quote me on that. lol.
Old Oct 27, 2009 | 08:44 AM
_Pirate_'s Avatar
Actually I only hooked up the noid light to one injector...I will check them all when I get home.
Old Oct 30, 2009 | 07:52 PM
_Pirate_'s Avatar
Jesus I"m a retard. I forgot to install the opti. After I did that and hooked everything up, the noid light on the previous injector light flashed. I went to do the next one but the Z is out of battery. I'll charge it and pull the fuel rail/injectors to see if fuel is getting out of them.
Old Oct 30, 2009 | 08:29 PM
  #20
rwing7486's Avatar
just a heads up i got a new opti from summit and my car still wouldnt run right / start. when i could get it to turn over it would idle sporadically miss fire and then die. After a bunch of testing on the ECU and Wires I got summit to replace it for free and that solved it. So you might still have a bad opti
