would tranny be able to handle..?
I have a 96 z28 auto and I'm about to do a cam swap w/ LE1 ported heads, i also want to switch my rear gears from 273 to 342, but i was wondering if my 4l60E tranny w/ 70k miles on it would be able to handle both of these? or either of these? im kinda just assuming (hoping) itll handle this cam swap. but if not is there any fairly easy/decently priced way to build it up to be able to handle the cam&heads/gears?
heres a couple places to find parts and info. servo is one thing. have a look you may want to change the converter. trany should handle the motor. like you say its getting on in miles though.
http://www.700r4l60e.com/
http://www.transmissioncenter.net/4l...rmance%20Parts
really? so the tranny would be able to handle the power easier changing to 342s? soo would it most likely be totally fine with getting this cam swap and gears? and thanks for the links craby
fare sized cam and 1.6 rockers, wont idle well below 900. loads up. anything over 1000 the stock coverter was kicking in and sometimes it wants to idel at 1100. i really like this trany and once its tuned right with the 373s its gona make me want more hp. lol.
