WOT stumble... TPS?
Good morning all... its time I get started getting the Camaro running 100% so i can start the bolt ons... doing an oil change, tranny fluid/filter change, rear end fluid change, and a coolant flush along with some other odds and ends... first things first, the SES light isn't on, but sometimes at a stoplight, the car idles high and almost wants to stall, and when you go from part throttle to WOT, the car hesitates, stumbles, and backfires and then goes, but if i stop the gas a couple times and then go to WOT, it goes pretty good... is it possible the TPS is bad or can it be something else? Thanks... I made a post in the Projects section of the Fourth Gen, I was going to try to keep all questions and answers on one thread but nobody responded... sorry if I'm post whoring...
test your fuel pressure. number 33 on the list here 4th Gen LT1 F-Body Tech Aids how old are your plug wires? could be the wires are getting weak and or plugs are failing. flash for codes number 23 on the same list.
hmmmmm
what could it be??
timing could be off
fuel trim incorrect
plugs arc'ing or misfiring
etc etc etc
as with building a home, it's best to have a good foundation
a new fuel filter, air filter, new plugs and wires
those are inexpensive and if you had long tube headers, new plugs and wires aren't bad.
with stock manifolds....................good luck
so, are you really going for bolt ons? Do you have the money? If so, then seriously, do the headers/y-pipe and plugs/wires at the same time. Also check the sticky about installing headers for the other items.
it also doesn't hurt to check your fuel pressure but only after a new filter.
if you are still popping ( i said popping with one o) after all of that, then my gut would be O2 sensors or optispark
but, don't go tossing parts for the heck of it
oh, if you are changing tranny fluid/filter because of slipping issues then that won't fix the problem; it's a bad tranny
what could it be??
timing could be off
fuel trim incorrect
etc etc etc
hmmmmm
what could it be??
timing could be off
fuel trim incorrect
etc etc etc
what could it be??
timing could be off
fuel trim incorrect
etc etc etc
good point
it's 19 years old and probably still has many original hoses
to the OP
you are doing what i call "make ready work" and I do that as well with newly acquired cars but also flush the brake fluid while inspecting/servicing the brakes.
I have lengths of several size hoses in my garage as well as various clamps
I make it a point to replace hoses as well.
