LT1/LT4 Tech 1993-1997
is it worth it
Old Jan 5, 2012 | 10:42 PM
dogdog130's Avatar
Default is it worth it
is it worth doing a 383 stroker or just a full cam to lt4 swap
Old Jan 5, 2012 | 11:49 PM
numskull223's Avatar
To be honest i have never been a 383 fan. But when I built one for my S10, i started liking them. Then when i got this Z, i fell in love with them. My cuzin Z with a couple of bolt ons cant even come close to my Z. 383 built right is a nasty lil engine.
Old Jan 6, 2012 | 10:10 AM
dogdog130's Avatar
yea just this project car i have 8K to put in it and i think it will cost 4 just to install machining and not including the kit
Old Jan 6, 2012 | 12:36 PM
BasicConcepts's Avatar
Technical User
i priced a 383 rotating assembly (scat) a whole drivetrain kit with cam and the machine work to the block at about 2400$
Old Jan 6, 2012 | 06:58 PM
dogdog130's Avatar
where at bec ill call them and get it done this week lol
Old Jan 6, 2012 | 10:09 PM
Technical User
i was looking on summit for the parts and theres a local shop that will do my machine work for about 400$
parts come to just about 2000$
[url=http://www.summitracing.com[/url]
i couldnt get a link to my shopping cart but heres the text
Cloyes Gear C-3039 - Cloyes Heavy-Duty Timing Sets
+ Add Notes
Timing Chain and Gear Set, Heavy-Duty, Single Non-Roller, Iron/Billet Steel Sprockets, GM, 350, 5.7L, Set
Part Number: CLO-C-3039
Estimated Ship Date: 1/9/2012
$85.95 Update
GM Performance 12480002 - GM Performance LT4 Hot Cam Hydraulic Roller Cam Kits
+ Add Notes
Cam and Valvetrain, Hydraulic Roller Tappet, Duration at .050 in. 218/228, Lift .525/.525, Chevy, 5.7L
Part Number: NAL-12480002
$649.95 Update
SCAT Engine Components 1-91055 - Scat Engine Rotating Assemblies
+ Add Notes
Engine Rotating Assembly, Series 9000, Cast Crank, Forged Pistons, I-Beam Rods, Chevy, Small Block, Kit
Part Number: SCA-1-91055
$807.95 Update
Oversize
Sealed Power Z2601650 - Sealed Power Gasket Sets
+ Add Notes
Gaskets, Full Set, Chevy, 5.7L/350, Set
Part Number: SLP-260-1650
$185.99 Update
Summit Racing SUM-227703 - Summit Racing Street & Strip® GM Throttle Bodies
+ Add Notes
Throttle Body, Twin 58mm, Aluminum, Satin, Chevy, Pontiac, Camaro, Corvette, Firebird, 350/5.7L LT1, Each
Part Number: SUM-227703
$244.95 Update
Old Jan 6, 2012 | 11:36 PM
too small for a 383, go bigger.
Old Jan 7, 2012 | 01:25 AM
dogdog130's Avatar
Old Jan 7, 2012 | 02:08 AM
tt383lt1's Avatar
my 383 on na pushed about 600hp on the crank with pump gas. its well worth the money if you do it right. but you need some heads to go with the 383. a 383 with stock head isnt going to do much in my op. but you get what you pay for. i dont like scat or eagle.
but what is ur hp goal.
Old Jan 7, 2012 | 02:14 AM
tt383lt1's Avatar
but some bad *** heads and intake would do a number. btw i dint see any fuel parts or program. bolts, studs, in the prices. trust me every lil thing adds up quick i have 21k into my na engine. but if you only want 500hp go with a FI on a stock engine or heads and cam
