woohoo!!!!!!!!!!!!!!!
so i got the trans on and the exhaust leak fixed started her up and it sounds like theres a blower on the car... and its idling like its got the biggest cam ever... ill get a vid later my neighbors baby is sleeping now... btw about 20-30 min to bolt up the trans
thats what i was thinking... now that i think about it it looked like the hose that goes to the TB (not the one from the valve cover) was a little crappy ill try replacing that
so the po cut the trans cooler lines and used rubber... now my problem is i cant find where i wrote down which line is which. anyone know what line goes to the top of the rad
and someone here told me the stock trans cooler is junk can i just replace it with an external cooler and mount it in front of the radiator
I've never had a problem with the stock trans cooler in mine. You can always add an aftermarket one if you want, but I don't think it is necessary.
I'm not sure which line goes where though and it is too cold out in the garage for me to crawl under mine and look.
I seem to be lacking a much needed score card on you!
For the sake of my eyes, to save a re-read....where did the trans come from, out of, and miles on it? All the electrical hookups to it are hooked up?
![Wink](https://camaroforums.com/forum/images/smilies/wink.gif)
1 dead 3.4L
1 dead LT-1
3 dead transmissions
and a really pissed camaro owner
anyways got the trans from the junkyard out of a january 94 built chevy astrovan 2wd that was wrecked in the rear with 146xxx miles sticker on the windshield said running/totaled (my junkyard buys cars from auctions) electrical is good
#20
Hmmm...running doesn't mean "moving" though. That's a lot of work and time to go through to put in a trans that has 146k miles.
Was it a cargo van (worked hard)? Not trying to rub it in, just sayin.....
