Wiring regret
Please help I did something stupid I wired coolingfans to switch while leaving hooked up to harness. Then removed mistake coolingfans still work but airbag and absINOP lights are on dash makes braking dangerous. I didnt find any blown relays or fuses. Please help new member first time post Thanks.
Make sure that you put all the wiring back like they were. Did you unplug any other wiring connectors in or around the front end of the engine? I left a connector unplugged after doing a head gasket replacement and for some reason, it caused the airbag and abs inop light to energize on my dash. I can't remember which one it was but am thinking it was a sensor that is in the elbow of the air intake. As soon as I plugged it back into the sensor, both the ABS and airbag lights went off.
Its been awhile since I caused it but dont think airbg,absinop came on till I switched on fan and around relay box abs could hear something repeatedly switching on and off then i had to unhook battery to reset it. I will recheck wiring tomorrow. Thanks alot really done it this time get back to u.
several times months ago i then found the ground on the fenderwell had worked itself loose i could move it by hand wish i had put wrench on it months ago. Thanks to u i wouldnt rechk it lights off dash and brakes work great.
