Wiper Problem...HELP PLEASE :)
So I have a 94 Z and the wiper blades will not go back into the normal resting position. When I turn them on, they work fine but once i shut them off...they just stop and don't go down at all. If anyone knows why that happens or how to fix it please let me know!!
The wiper park switch is under the cover on the wiper moter. When you shut off the wipers it is supposed to power the motor untill the wipers reach the bottom of the wiper stroke, and depress to park. You might have a bad switch or the linkage in the motor is jamming the switch in the open position.
wiper motor circuit board is bad. u can get just the board or the whole unit, motor and board. probly better to get the whole unit so u wont have to worry about it again. like most things on these cars they are not an easy fix. not as hard as changing plug wires though. wiper motor is in the little space up under the cover thats under the wipers on the drivers side.
