wheels and tires
depends on the ride height and backspacing of the wheel. If you have stock ride height you can push the tire outside the fender well and go wider. But for a pretty much stock wheel, you can go 17X11 with a 335/40 tire. I would check with a tire shop before you do anything, they can tell you exactly what you can do.
This is just for the back BTW.
