LT1/LT4 Tech 1993-1997
wheel bearings on a 1996 Z28.
Old Oct 8, 2009 | 09:57 AM
aaron_Z28's Avatar
Default wheel bearings on a 1996 Z28.
so i was just wondering how hard is it to replace them because they are making an awful noise and causes my handling to be really bad.
what is all needed to get them fixed?
should i just get them done professionally or easier/cheaper to do it myself?
i have a tire question.
i have 225 16s up front and 255 16s out back.
what is the biggest i can go on the stock rims for both front and back?
if i put 255s on front and back will it wear out my front end quick?
thanks for the help guys and gals.
Old Oct 8, 2009 | 01:16 PM
aaron_Z28's Avatar
about how much are the parts for the bearings?
Old Oct 8, 2009 | 04:23 PM
i cant remember the cost but im thinkin it was a pretty good sum like 5 hundred for both. that was a couple yrs ago so im not sure. there not to hard to change and if u havnt had a brake job in some time now would be a good time cause ull be taken them off. thats the hardest part. u dont just change the bearings u change the hub also so u really dont mess with the bearings themselves. its four bolts and a speed sensor wire.
Old Oct 8, 2009 | 04:59 PM
aaron_Z28's Avatar
yeah i knew the hubs had to be changed. i just wasnt sure of the price.
Old Oct 9, 2009 | 04:03 AM
contryboy's Avatar
150 + taxs from the autozone for a hub and bearing assembly. 55+ tax on the cmax pads. check ur rotors and see if the need to be refinished while u gotem off shouldnt take a brake shop a day or so its worth it cuz u dont want to be doin that tear down again. check ur lines u know the usual wear and tear stuff. preventative maitence will always safe u alota crud from tearin up later on down the road
Old Oct 10, 2009 | 12:36 PM
aaron_Z28's Avatar
thanks for the help guys.
98camarov6
Jul 26, 2012 12:11 AM
chad kennith
Oct 13, 2011 10:10 PM
microkid
Oct 26, 2009 07:36 PM
Jul 1, 2008 04:16 PM
Cam Can
Nov 21, 2007 08:54 AM
