LT1/LT4 Tech 1993-1997
What to do next?
Old Nov 30, 2011 | 07:01 PM
Cliff123454321's Avatar
Default What to do next?
What do I do next to my z28?
Already has:
CRS electric fuel pump
All MSD ignition
BKK headers to straight 3" borla adjustable exhaust no cats
Bored throttle body ns mass sensor with larger K&N cold air intake
Transpak shift kit (strip)
stronger rear end alloy axel
Tubulor control arms with adjustable panhard bar
Zr1 Corvette tires, 12" in the rear
Old Nov 30, 2011 | 08:08 PM
get it tuned here LT1 PCM Tuning - OBDI/OBDII PCM Tuning/Programming Service
long term get lloyd to do a le2 job on your heads and do the intake and pick up a cam from him as well. 1.6 roller rockers. http://www.elliottsportworks.com/ then have it retuned.
Old Nov 30, 2011 | 08:58 PM
JGuy07's Avatar
A minor tip for the electric wp would be to wire in a warning light or alarm of sorts to let you know when the pump fails and what not, have seen quite a few people mention that as a safety precaution.
NVM, read it and you didn't say you had one. Hey, that could be your next task.
Old Nov 30, 2011 | 09:58 PM
It does...idk why I wrote electric fuel pump, ment water pump :/
