LT1/LT4 Tech 1993-1997
what do i say to the muffler peole
Old Feb 10, 2007 | 08:32 AM
kyleb's Avatar
Default what do i say to the muffler peole
if i bought these: http://cgi.ebay.com/ebaymotors/93-94...77769164QQrdZ1
i have them put them on (i cant right? need to weld?) and then i tell them wat? i want a duel exhaust
tell them i want costom madel bent tubbing (3inches?) to, twohi flow cats? and somhow make it work with my exhisting muffler or at least the tips(i really like the tips on my car)
-i dont completely understand, but i do want a real dual ehaust not, 1 pipe going into a single inlet mufler with dual outlet!
Old Feb 10, 2007 | 11:56 AM
Andross's Avatar
Default RE: what do i say to the muffler peole
Just explain that to them the same way. They'll understand
Old Feb 10, 2007 | 04:18 PM
kyleb's Avatar
okay i wasnt sure if all that was makin sence cause meybe i had it backwards er somthin, what didameter is good on our cars? 3inches right?
Old Feb 10, 2007 | 04:23 PM
Andross's Avatar
I have 2 1/4 on mine. I dont know if I personally would go more than 2 1/2 though.
Old Feb 10, 2007 | 04:31 PM
95slvrZ28's Avatar
You won't need to weld it, but you either have to weld it or clamp it, either way(my headers utilize band clamps to get into the Y). If you're looking for a true dual, you won't be able to fit 3 inch all the way back, you simply can't due to ground clearance issues(that's why true dual on a 3rd or 4th gen doesn't work). If you're getting a muffler shop to do all the bending and installation of the headers, get ready for a big labor bill.
Old Feb 10, 2007 | 04:45 PM
kyleb's Avatar
wiat what? they have to bend the headers?
true dual(meaning the y pipe) isnt good for us? should i just stick with the way mine is now?
Old Feb 10, 2007 | 06:36 PM
ghotachevy's Avatar
dual exhaust is two pipes all the way back there isn't room to do it in front of rear end that's why its a two into one back to two
Old Feb 10, 2007 | 09:29 PM
kyleb's Avatar
so then its kinda like an "H" ?
so it goes: headers, then then the y-pipe conects to that. two pipes rune of each side of the y-pipe and goes to a muffler with dual inlet and and the tipps come off the outlet? where would the catlatic convertr be in this?
or you can do the same thing with out the muffler and addcats in the place of the muffler?
sory for the dumb questions but i realy wanna learn this
Old Feb 10, 2007 | 09:53 PM
kyleb's Avatar
i found under the stickeys
can somone edit the rest of the pictur or show me how it should look
that would help me alot. can fix it by using paint er somthin
http://shbox.com/1/exhaust_system.jpg
Old Feb 11, 2007 | 03:21 AM
95slvrZ28's Avatar
The exhaust that fits goes from the headers into a Y, depending on your year, you either have one cat after the pipes Y together into one, or you have 2 cats before they Y together. If you go with headers, you'd be dumb to run a single cat. So, you'd have Long Tube headers that you'd purchase(Hooker, Kooks etc.) and a Y pipe from the manufacure you purchased the headers from to insure it fits. This Y would need to have the cats in it. Then you could either install the header and Y setup yourself(give youself a good amount of time), or you could take it to the muffler shop and have them install it. Once that is in, you can either have them weld the stock midpipe back on(you'd have the muffler/tips and the part of the pipe that goes over the axle), or you could replace the whole midpipe with a new cat back exaust system. Do you follow what I'm saying or would you prefer a picture?
