LT1/LT4 Tech 1993-1997
What to do.....
Old Jan 30, 2008 | 08:33 AM
bowtie4ever's Avatar
Default What to do.....
I have an oppurtunity to get an'04 2500 HD with the 6.0 liter, I can get the truck for 1800.00, and I have a 95 camaro w/ 3.4 V-6, I know the extent of this swap, but I was wondering if anyone has any tips that could possibly help? I consider myself a shadetree mechanic and would feel very confident about the swap, (I'm not stupid!!!!), I think the power of this car would be well worth the trouble of the swap, I know I need throttle by wire,catalytic converters,MAF, fuel pump to keep up, everything.... has anyone done this besides GM?????, any pointers??????
Old Jan 30, 2008 | 08:59 AM
whammer3024's Avatar
ROTM Winner
Default RE: What to do.....
my question is why is the truck only 1800 bucks? that throws up a red flag to me
Old Jan 30, 2008 | 09:01 AM
I work for an oilfield company that miles them out at 180,000 miles, the motor would be rebuilt....
Old Jan 30, 2008 | 06:56 PM
robmnrd's Avatar
Summed up: You wanna swap the 6.0 from a truck...into your camaro...
I have no tips, but I wish you all the luck in the world. And if/when you finish, you bettercome pick me up. [8D]
Old Jan 31, 2008 | 12:33 AM
Spartan66's Avatar
if you want a 6.0 liter get an LS engine from the GTO.
Old Jan 31, 2008 | 12:56 AM
luvmysccamaro's Avatar
whats the point off spending an extra $6000 when he already has a nice motor for $1000? sounds like a waist of money to me.
Old Jan 31, 2008 | 01:18 AM
Spartan66's Avatar
What you all seem to be missing here is that Truck engines are tuned differently than sports engines... their engines are built for towing... meaning high torque.. our cars are tuned for speed and performance..
Old Jan 31, 2008 | 06:23 AM
94Z28SHAKER's Avatar
actually, anyone who is into racing/building motorswill tell you that the 6.0L in that truck is the perfect motor, its basically the same as the LS2 in the GTO/vette except it is an iron block, and has a cam designed for a truck with high torque. so its definately much stronger than the aluminum block LSx motor and only a little heavier.
get your self a custom grind cam, that builds HP higher up in the RPM band, with a good tq curve, maybee when they rebuild the motor they can throw it in for you.
you will for sure need custom fabbed motor mount's.
you will need a trans to support the power, a newer trans from a trailblazer SS should work.
you will need to beef up the rear end.
Old Jan 31, 2008 | 10:05 AM
ROTM Winner
ifyou can afford everything then i'm all for it. take your time and make sure the rebuild is done right! i'm anxious to see if you go through with it!
Old Jan 31, 2008 | 05:22 PM
I will thanx bros
