what are the best quick mods???
I was just wondering what are the best quick mods for a lt1 6speed for some horse power. throttle bodies?? Intakes?? chips?/
what do you guys suggest without emptying my wallet?
CAI, cat back, 4.11:1 rear end gears. Changing gears will make a difference you can really feel, but it will cost you in gas. Bigger throttle body won't do much unless you are going for internal mods, and IMO chips are a waste of money. Get a dyno tune instead of a chip.
Go check out the "Where to start modding" thread in the 4th Gen section, it has the "normal" order of common bolt-on modifications. Once you get a CAI and full header back exhaust you get into big-boy territory with internal mods if you're looking to generate more HP. Gears and a higher stall (if you're running an auto) don't get you any actual HP, but they will help improve a 1/4 mile time if configured correctly.
Power is all about money, how fast can you afford to go?
