LT1/LT4 Tech 1993-1997
What is it??
Old Dec 5, 2010 | 03:31 PM
Jared Cassedy's Avatar
Default What is it??
so i was wondering what is this green plug? the other day it broke but i got it to go back on and i think it has something to do with my tranny not wanting to shift in drive unless you get going fast. car is a 93z28
Old Dec 5, 2010 | 03:32 PM
BasicConcepts's Avatar
Technical User
i think its the MAP sensor
Old Dec 5, 2010 | 03:51 PM
thanks. do you know if it has anything to do with the transmission?
Old Dec 5, 2010 | 04:04 PM
ChevyManCam's Avatar
all i have to say for this is
Old Dec 5, 2010 | 06:48 PM
Grandpaswagon's Avatar
That is your MAP sensor and it has nothing to do with your transmission shifting.
Did you check the tranny fluid? You just bought this car, is that correct?
Old Dec 5, 2010 | 09:32 PM
Yes it was low so I filled it. And yeah I've had the car for a few weeks.
Old Dec 6, 2010 | 09:12 AM
Did adding the transmission fluid correct the shifting problem? Did you see any signs of leakage? Normally the 4L60 won't leak a drop so a sign of a leak is something that needs to be addressed.
Old Dec 6, 2010 | 08:24 PM
have you adjusted the tv cable? make sure its not broken or unhooked.
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old Dec 7, 2010 | 01:16 AM
I haven't touched a thing on it. Car just sits and will probably just sell
Old Dec 7, 2010 | 09:32 AM
Other than the shifting problem (is it fixed now?) and your cooling issue, what else are you having trouble with?
