LT1/LT4 Tech 1993-1997
water pump gear?
Old Oct 20, 2009 | 09:22 PM
r6rider's Avatar
Default water pump gear?
not quit sure what it is called but i have an electric water pump that im putting on the motor that im building at the moment and i was told that i can just get a plug for the timing cover so i dont have to us that water pump gear?
Old Oct 20, 2009 | 09:52 PM
That was easy...Water Pump Plug
But why do you want to go with an electric water pump?
Old Oct 21, 2009 | 12:20 AM
r6rider's Avatar
cause i already have it from when i pulled the motor (the guy before me installed it) so i mine as well keep it.
Old Oct 21, 2009 | 12:52 AM
383Stro's Avatar
That plug calls for some welding, time to fire up the old tig and i hope u dont have the plastic timing cover that is floating around as a replacement for the gm aluminum one.
Old Oct 22, 2009 | 02:36 PM
sm515's Avatar
use a Canadian looney dollar!!! and weld it in there....now thats cool....if ur Canadian...ha
Old Oct 23, 2009 | 01:15 PM
r6rider's Avatar
nope i still have the gm one. do you guys thinks its worth doin all this. or would it be better to just throw the gear back in
Old Oct 23, 2009 | 01:28 PM
For an every day street driven car, I would prefer a mechanical water pump. If the electric pump ever fails (electric motors live only so long), you're stuck at the side of the road overheating. A mechanical water pump will rarely go out to the point where you can't limp it home, or at least to somewhere more convenient.
Old Oct 26, 2009 | 02:42 AM
r6rider's Avatar
it says that the plug is for 94-97 i have a 93 motor is there something diffrent between the 93 and the 94 timing cover that i cant get this plug?
Old Oct 26, 2009 | 09:04 AM
93 has a different size hole for the seal. its smaller than the 94-97
Old Oct 26, 2009 | 11:46 AM
Maybe you can find someone to turn it down on a lathe, if a smaller one isn't available.
