tweek my build list
tweek my build list
Im just in the first stages of my build, breaking the engine down and such, here is my "list" of things to buy to complete. Anything i forgot or should change?
TOP END
SUMMIT: ARP Head Bolt Kit PN: ARP-134-3601 - $75
SUMMIT: Sealed Power Gasket Set, PN: SLP-260-1650- $1 80
SUMMIT: Proform Roller Rocker Arms PN:PRO-66915 $190
SUMMIT: Summit Throttle Body Dual 58mm, PN: SUM-227702, $229.95
SUMMIT: Comp Rocker Arm Studs PN: CCA-4502-16 $34.00
SUMMIT: .039 Felpro Headgasket PN:FEL-1074 $57.00
JEGS: GM High-Performance Lifter Kit, PN:809-12371042 - $230
Elliot Powerworks LE2 Complete Head (54cc) W/ cam 230/240 .576/.574 110 LSA - $1600
Elliot Powerworks LE Intake Portwork - $200
*Pushrods
TOTAL: $2,796
BOTTOM END
JEGS: Complete Freeze Plug Kit PN: 555-58000 - $13.99
Summit: Timing Gear Set PN: LUN-93094 - $109.99
Summit: ARP Main Stud Kit PN: 134-5502 FROM ARP, $80
Summit: Scat 4340 Forged Steel Crankshaft, 3.480 Stroke PN: SCA-435010L $660.95
Summit: Compstar H-Beam Connecting rod 6.000 Length with ARP Rod Bolts PN: CPI-A6000DS2A2AH $589.99
Jegs: Mahle Forged PowerPak Piston Kit (-5cc) PN:644-SBC250030F05 $652.99
Rod Bearings
*Main Bearings
*Cam Bearings
TOTAL: $2117
IGNITION/FUEL/EXHAUST/OIL SYSTEM
Chandler Motorsports : Optispark Distributor PN: 10457702 $170.00
Summit: GM Performance HP Oil Pump PN: NAL-12555884 $82.00
Jegs: GM Performance Sump Pickup PN: 809-3855152 $30.00
Summit: Accel Coil PN: ACC-140011 $47.95
Summit:Trick FlowFuel Injectors PN: TFS-89036, $350.00
Summit: Granatelli 255 Fuel Pump $125.00
Summit: Pacesetter Longtube Headers PN: PSM-70-2239 $292.69
Summit: Pacesetter Y Pipe PN: PSM-82-1161 $125.00
Caspers Electronics: 02 Sensor Extensions PN: 109011 $50.00
Miscellaneous parts: Plugs, sensors, oil, filters, battery ect. $500
TOTAL: $2000
TUNING: $85 LT1tuning.com
Summit: Powermaster XS Torque Starter PN: PWM-9502 $219.00
Summit: Canton Racing Valve Covers PN: CTR-65-206 $195.00
Summit: EGR Block-Off Plates PN: RFW-EB2 $25
TOP END
*Pushrods
TOTAL: $2,796
BOTTOM END
Rod Bearings
*Main Bearings
*Cam Bearings
TOTAL: $2117
TOTAL: $2000
1343601, 702239, arp, bolts, camaro, connecting, end, forged, forum, lt1, pacesetter, performance, rods, summit, top
