LT1/LT4 Tech 1993-1997
turn signals
Old 07-20-2010, 11:43 AM
if its flashing on one side the flasher is good. the bulb should be a 1157 or like that and is a double element bulb. if you get it in wrong like duck says it can mess with things. bad ground will also mess with it and i have found that to be the problem on a few of my cars.
Old 07-20-2010, 12:28 PM
something to look at
Size:  46.2 KBName:  P7190003.jpg
Size:  37.0 KBName:  P7190005.jpg
Old 07-20-2010, 04:25 PM
Stix80's Avatar
ok sorry didnt relize it was flashing good on one side check that you have the correct bulbs and then check your grounds
Old 07-21-2010, 12:54 PM
ayagle's Avatar
problem solved.. it was a bad ground in the socket, just had to open the connector up a little to get a better connection thanks again everyone...
cooleric2000
08-09-2010 12:45 PM
WIspartan1026
05-11-2010 10:47 AM
z28-94
05-24-2009 03:15 AM
BAV
03-09-2009 02:18 PM
got3ofem
07-18-2007 04:47 PM
Quick Reply: turn signals
