Turn Signal Problems
when I put on my left turn signal, the light just stays on and doesnt blink. I have replaced the front and rear turn signal bulbs and checked the fuses. But here is the kicker, the emergency flashers work on both sides. Any help is greatly appreciated.
Robert
Robert
sounds like the turn signal flasher relay is out i had that problem as well, it would click on but not blink. look up the diagram on google for your year model, im sure there is one out there. its a cheap 5 dollar part at your local auto store. and yes the emergency flashers will work because they run on a different relay than your individual blinkers. hope this helps, good luck!
its under the panel on the drivers side underneath the steering column.I also believe its the turn signal flasher.There are two seperate flashers,one for the emergency signals and one for the turn signals
^^^ yep there are two flashers one for the four ways and one for the blinkers. on my car the one for blinkers is under the dash on the driver side up the stearing column. need to take the plastic off to get to it.
