Trying to find the oil pressure senor 1994 Lt1
I have looked all over for it. The manual says its a 3 wire deal.. I can not find any thing like that on the whole engine.
I see what looks like a sensor just above the oil filter. But its just a single wire and nut post sensor..
My Oil pressure gauge is pegged all the way to like 100... And I got a check guages light on...
That sensor that is in the location you are showing does not look like that one.
Mine has a threaded top with a nut holding a wire on.
Yours a 93? Mine is a 94 and saw that it could be up on the back side of the intake manifold area.. I going to look today and see if Its there..
My FSM shows it on the driver side of block right behind the engine mount...
I dont know what was done to this engine in the past or anything ...
Just trying to fix things as I see them.
If anyone has a link to the correct 1 wire sensor I will appreciate it please..
Cause ALL i am finding is the 3 wire ones... Part number or something like a link to it would be GREAT..
well found this,, Think the connection only uses 1 of the pins in the sensor..
SO the sensors I am seeing at parts store should work even though they have 3 pins..
Now I got to find a connector to work with it..
