TRANSMISSON
RE: TRANSMISSON
The 93 Camaro is different from the rest of the 4th gen cars. The transmission is a 700R4/4L60, not the electronic 4L60E like the newer cars. The only thing that the PCM controls, in the 93, is the TCC application.
A shift kit will work, but be careful as to what stage you choose, as the shift can get pretty nasty and PIA in normal driving. Also specify that you have a 93 model.
RE: TRANSMISSON
Get a kit that is for street use, it will give firmer shifts without hurting your neck.
http://transgoperformance.com/gm700r4.htm
http://store.summitracing.com/egnsea...956+115+400004
RE: TRANSMISSON
Not necessary, but it will make part throttle shifts more bearable, and also get the car off the line quicker. Also the high stall creates a lot of heat, and requires an aux trans cooler.
RE: TRANSMISSON
Simio....I believe the 93 has the electronic version of the 700r4....the 4L60E....basically the same transmission except more electrical control and crap to break.....LOL....gotta love technology.
#20
RE: TRANSMISSON
ORIGINAL: nuttyprofessor
Travis_216
10-20-2013 03:36 PM
