LT1/LT4 Tech 1993-1997
Torque specs for lug nuts
Old Jun 16, 2010 | 05:52 PM
REN's Avatar
REN
Default Torque specs for lug nuts
Can't seem to find the exact specs in the manual. Anyone have recommended specs for lug nuts for 96 camaro with stock wheels? Thanks
Old Jun 16, 2010 | 06:11 PM
Cammy 3.8lV6's Avatar
ya know I've never even specified an amount of torque on any car i've put a wheel on - just put it on 'tight' without killing it. Haven't had a wheel fall off or come loose yet.
Old Jun 16, 2010 | 06:15 PM
I normally use a breaker bar, and go by the ehhhhhhhh method!
Once you've installed and removed wheels enough times, you know what is tight and what is too tight without using a torque wrench.
Old Jun 16, 2010 | 06:39 PM
Massey's Avatar
Just don't "spot torque" the lug nuts. spot torquing is torquing the nuts so tight you see spots.
When I was a tech for GM we would set the steel wheels at 75 ft lbs and the aluminum ones at 85 ft lbs
Massey
Old Jun 16, 2010 | 07:51 PM
lol, Good one.
Old Jun 16, 2010 | 08:31 PM
93 factory book calls for 100 ft lbs. i do mine at 90 and the tire shop i got the wheels from recomended 90. use the star pattern when tightening and use multiple passes snug- 30- 60- 90. last thing you want is an uneven torque job. that can mess up the rotor.
Old Jun 16, 2010 | 09:17 PM
ricer_killaZ28's Avatar
yeah anywhere from 90-95 is good. I learned that the hard way.. didn't have a torque wrench so just did it realllly tight. next time. had to use wd40 to get them off haha
Old Jun 17, 2010 | 10:22 AM
skywurz's Avatar
This page says 100ft-lbs http://www.bfranker.badz28.com/fbody/torquespecs.htm
but i find that some of the specs differ from book to book i think my chilton says 90ft-lbs
Old Jul 14, 2013 | 08:50 PM
libertyforall1776's Avatar
Ancient thread I know, but here's the definitive answer from GM eSI, since I was searching for the same information:
"Tighten the nuts in a cross sequence to 140 N·m (100 lb ft).
Tighten the wheel nut caps to 6 N·m (53 lb in)."
Old Jul 16, 2013 | 01:56 PM
I have not put a tire on a car without a torque wrench since I was 17. 100 Ft lbs unless it one of those large franged 80's sytle aluminum mag wheels, then I do 80 ft lbs.
GM says most rotor warpage is caused but uneven torque on wheel. I have never warped a set of rotors on one of my cars. My wife tends to ride the brake, even tho her wheels are on right she warps them in about 2 years. So GM is full of it
Tipsy
Jun 9, 2014 08:06 PM
Chevynutz
Feb 25, 2012 11:44 PM
Freeksen
Jan 28, 2011 04:02 AM
95z281LE
Jan 15, 2008 06:11 PM
SickSickSick
Jun 25, 2006 01:07 AM
