LT1/LT4 Tech 1993-1997
timing chain
Old Dec 30, 2006 | 07:07 AM
KoRN_Munky's Avatar
Default timing chain
what kinda timing chain comes on lt1's? cause when i do the cam i wanna put a roller timing chain on there.
Old Dec 30, 2006 | 01:10 PM
Default RE: timing chain
Can't use roller timing chain on LT1 without a lot of mods to the front of the engine. You can use the heavy duty chain & gears from teh LT4, but it is expensive, and still not a roller chain.
Old Dec 31, 2006 | 12:37 AM
KoRN_Munky's Avatar
so when i change cams just reuse the old chain?
Old Dec 31, 2006 | 01:21 AM
You should put in a new chain & timing gears, the oldchain is probably stretched out and the gears a little chewed up.
Old Dec 31, 2006 | 08:02 AM
KoRN_Munky's Avatar
well i might as well put the LT4 ones in then since they are more heavy duty
NorthernCrew454
Oct 5, 2011 11:59 AM
Chevy101
May 25, 2011 05:00 PM
JordanN
Aug 23, 2010 07:13 AM
inavacuum
82-92 V8 Tech
Apr 1, 2009 03:43 PM
Z28man
Oct 6, 2006 04:13 PM
