timing chain
what kinda timing chain comes on lt1's? cause when i do the cam i wanna put a roller timing chain on there.
RE: timing chain
Can't use roller timing chain on LT1 without a lot of mods to the front of the engine. You can use the heavy duty chain & gears from teh LT4, but it is expensive, and still not a roller chain.
RE: timing chain
so when i change cams just reuse the old chain?
RE: timing chain
You should put in a new chain & timing gears, the oldchain is probably stretched out and the gears a little chewed up.
RE: timing chain
well i might as well put the LT4 ones in then since they are more heavy duty
