LT1/LT4 Tech 1993-1997
Ticking Sound and hesitating/stumbling
Old 12-31-2006 | 10:07 PM
jdpeters's Avatar
Default Ticking Sound and hesitating/stumbling
My camaro sat for 6 days covered in snow during the blizzard in Denver last week. When I drove it for the first time, I noticed that it was running rough and hesitating/stumbling at all rpms. I've been told I might have water in fuel system or clogged injectors. Now I hear a tick coming from the engine (I can't locate it, but I think it coming from the upper part of the engine and I canhear it while I'm driving). The ticking is really the thing making me nervous.
Any thoughts? Thanks!
Old 12-31-2006 | 10:20 PM
jtvyper456's Avatar
Default RE: Ticking Sound and hesitating/stumbling
Water in your oil maybe, happened to my bro-in-laws 92 RS, he ended up letting the oil drain all night and then refilling the next day, also ended up having to get new gaskets, got rid of the tick.
Old 01-01-2007 | 12:36 AM
Common problem. Snow got blown in the engine compartment during the blizzard. When engine was started the snow melted and got the ignition wires wet. The ticking is caused bythe sparks jumping out of the wires. This causes misfires and makes the engine run bad. Try to spray the plug wires with stuff made for that purpose. If it does not help, change the wires and plugs as the plugs with the bad wires are most likely fouled. The Optispark may have gotten wet also, and if that happens it craps out. Clean snow out of engine compartment after blizzard before starting engine. LOL
PatrickM
04-06-2013 08:09 PM
bdam0214
67-69 V8 Tech
10-28-2008 12:24 PM
terrychamp01
05-01-2008 09:57 AM
partyboy8050
04-14-2008 11:53 PM
amaster
03-12-2008 07:39 PM
