ticking sound under the valve cover
Old Oct 27, 2008 | 12:22 PM
bdam0214's Avatar
Default ticking sound under the valve cover
1969 rally sport with a 350
Anyone have any ideas as to what a ticking sound coming from under the valve cover would be?...and the car is back firing on hard
acceleration.Rocker hitting the valve coveror deposits on the valves???? Thanks for the help.
Old Oct 27, 2008 | 12:58 PM
Default RE: ticking sound under the valve cover
ORIGINAL: bdam0214
Anyone have any ideas as to what a ticking sound coming from under the valve cover would be?...and the car is back firing on hard acceleration.
Sounds like a valve is either not working, or just barely.You'll want to pull the valve cover off to inspect.
1) Look for any obvious rocker arm damage, or a possible loosened nut.I oncehad astock steel rocker arm wear so bad thatthe push rod actually launched itselfthrough the arm.
2) By hand, check all the rocker arms to see if any are sloppy. With the coil wire disconnected, tap the engine over a little and check them again, then do it again. If they are sloppy, adjust them.
3) Your cam could havea wiped-outlobe. Whilecranking the engine over with the valve covers off, look at each rocker arm. If you see little or no activity at a rocker, your cam is bad.
4) If after all the above, and you still have the noise, thena bad lifter would be the culprit.
For adjusting the valves, use whatever procedure you're comfortable with. But from past experience/results, I like this procedure better: Valve Lash Adjustment
Old Oct 28, 2008 | 11:24 AM
bdam0214's Avatar
Thanks, i will check it out.
PatrickM
Apr 6, 2013 07:09 PM
DarlingReject
Oct 4, 2010 11:31 PM
terrychamp01
May 1, 2008 08:57 AM
creck
67-69 V8 Tech
Mar 12, 2008 10:04 AM
jdpeters
Dec 31, 2006 11:36 PM
