LT1/LT4 Tech 1993-1997
Threw timing belt?
Old 08-15-2012 | 10:42 AM
BudBrown's Avatar
November 2011 ROTM
Ride of the Month Director
Just remeber, this never fails...
The minute you get rid of it, the new owner will make a $50- $150 fix and it will never have a problem again... dont get rid of it... take your time, be patient, it will be awesome.
  #82
Old 08-15-2012 | 11:26 AM
GreenMamba's Avatar
Yeah, i had a similar experience before. I had a little 87 S-10 ext cab, loaded with Tahoe package power everything, really nice. It died on me one day and wouldnt start again. I messed with it for awhile to no avail. I wound up selling it for money to move for half of what i paid for it. The guy i sold it to found the coil wire was grounding against the fender well. $6 and it was as good as new.
  #83
Old 08-30-2012 | 02:56 PM
jkeaton's Avatar
Originally Posted by GreenMamba
And to be honest, I really dont have the money to screw with it right now. Im really getting discouraged about getting it fixed. Starting to seem like a money pit.
You bought an (almost) 20 year old car. Unless the previous owner went through and replaced every mechanical wear component, your going to have to put money into it yourself. Then you also have issues like the previous owner butchering wiring or stuff like that. I little research goes a long way before buying a vehicle. My 94 has 180k. I KNOW it needed some rebuilding. For example, I had to immediately invest in an opti, plugs, wires, ICM, IAT, TPS, MAP, IAC, EGR/solenoid AND a code scanner so I could work on it myself. The I had to put an AC compressor on it to get air conditioning. Now I find out I got to put a steering rack on it. It's all part of owning an older vehicle. If your not financially ready to support it, you should have invested your money into a newer vehicle. Not being a smart a$$ or anything, but you have to realize what your getting yourself into.
  #84
Old 09-01-2012 | 09:17 PM
rain01's Avatar
I didnt do the replacement. The opti was replaced by the previous owner a week before i got the car. It was a RichPorter opti. I still have the box it came in and the old one. Somewhere (fingers crossed) i have the receipt from oreillys for the $240 something that he paid for it a month ago.
Say cheak your icm that little bugger will make your ride run bad as hell get them cold if they are bad and it will run fine for about 1min,really dont sound like an opti gone bad it would not have fired back up and ran good,i had the same thing happ i just redone my opti and 1 week later it would not crank,after taking the ICM off and putting it in the frezzer for about an hour i put it back on it fired up went and bought a new 1 problem soveld,give it a chance
  #85
Old 09-02-2012 | 05:52 AM
GreenMamba's Avatar
Good info. Problem is that it doesnt start at all. Hasnt fired up once since i started this thread.
  #86
Old 09-02-2012 | 07:45 AM
torque_is_good's Avatar
but you've posted you have access to a mechanic who will only charge $125 and all you need to do is flat bed it to him
It's been a month yet you haven't taken it to him?????????????????????
  #87
Old 11-07-2012 | 06:50 PM
GreenMamba's Avatar
Just an update, turns out I was right all along. Timing chain stripped.
  #88
Old 11-07-2012 | 10:22 PM
BudBrown's Avatar
November 2011 ROTM
That sucks a ton dude, you gonna get it back together soon?
  #89
Old 11-08-2012 | 08:09 AM
thats the first time i have heard of a lt1 gear failing. any metal in oil from it goin to pieces.
  #90
Old 11-08-2012 | 08:22 AM
jkeaton's Avatar
+1. A stripped timing chain?
Quick Reply: Threw timing belt?
