thinking about some more horse's ;-)
Ok so I'm ready to start adding some horsepower to the z... its a 94 lt1 so I know its obd1 and idk if that's going to be a disadvantage or not. now I don't have a lot of time with the car down as it is my daily driver... the mods I have know are its got the k&N CAI, msd coil and a borla catback exhaust into a centermount exhaust tip.. not really a mod but its got 315 sticky tires on the back. I was thinking of going with some short headers ( I live in cali so I got the stupid smog stuff to deal with) but what do you guys think? I appreciate it.
I was also thinking... would putting longer rocker arms over stock ones be the same as putting a bigger cam in it?
be a good idea to change the springs retainers guide plates and go with hardened pushrods. the stock LT1 cam with 1.5 rockers pushes .447/.459 and .477/.490 with 1.6 rockers. thats a pretty good jump. if you dont like the noise you can use stamped 1.6 rockers.
I wouldn't have any clearence problems with 1.6 rockers would I? Pushrods could stay the same length but just go with hardened ones? What kind of setup should I go with the Retainers and guideplates rockers and pushrods? And I don't mind the noise.
depends on what rockers you get. aluminum are bigger. pushrods would be a different length, look here
https://camaroforums.com/forum/93-02-general-41/measuring-checking-push-rod-length-51829/ these would be a good choice but overkill. http://www.thunderracing.com/shop-by...iners_815.html summit has some good guideplates. may as well switch to 7/16 rocker studs and go with 7/16 rockers. |
r u sayin that changing rocker arms would b that same as changing the cam? at least as far as the sound?
heres what i used, check my garage for the full list.
ARP 134-7103 7/16 rocker studs Trick Flow TFS-21407100 Pushrods, 5/16 x 7.100 comp cam 1305 roller rockers 1.6 7/16 pro magnum and yah it changes the lift by quite a bit. the stock LT1 cam with 1.5 rockers pushes .447/.459 and 1.6 rockers push .477/.490 |
o ok. ima leave my cam alone then and jus do my heads
your not going to get the choppy sound like a 112 overlap. will help with bolt ons. get between 8 and 13 hp gain depending on the other mods.
