tail lights
when you switch to led lights the smaller amount of electricity used can cause issues with the abs system and the blinkers. if you have issues, to correct you will need to install a resistor in the line on the brakes and use a different flasher on the blinkers.
vXIcetreyXv
10-23-2009 07:25 PM
bodykits
07-01-2009 09:52 PM
