LT1/LT4 Tech 1993-1997
Tach signal
Old Aug 6, 2025 | 07:55 PM
32rdstr's Avatar
Default Tach signal
Trying to hook up a Moon tach and it's come down to two wires which are both black. My ECU is located in the trunk and I extended the tach wire with a black wire. I would like to identify the tach wire by the output when the car is running. What kind of a signal should I expect when the engine is idling?
Old Aug 7, 2025 | 09:44 AM
this help so far this is all I have found
Old Aug 7, 2025 | 07:35 PM
32rdstr's Avatar
Solved! Turns out the tach signal is a square wave which starts out at 12 volts and goes DOWN with RPM. I was probing it with the key on and thought it was gauge power.
Old Aug 7, 2025 | 07:37 PM
32rdstr's Avatar
When in a hurry and just cut wires, label them even if it's just A-A, B-B, C-C etc. Saves time.
Dad9904
Jul 16, 2024 01:01 PM
adclark3@att.net
May 28, 2017 12:37 PM
blue_thunder01
LS Series Tech
May 23, 2010 04:52 PM
camarofreak1990
Oct 15, 2008 12:05 PM
SSmp5
Nov 6, 2005 12:21 AM
