LT1/LT4 Tech 1993-1997
t-56 removal
Old Apr 17, 2010 | 01:25 AM
noz's Avatar
noz
Cool t-56 removal
95 z28 replacing my engine, guys i need help everything was going so beutiful till i got stuck with my t-56, my engine is like 3 inches away from the trans and it just wont come out got kinda frustrated so i will try it on sunday ....any trick to this thanks guys..
Old Apr 17, 2010 | 08:25 AM
being u have a pressure plate to deal with i would say its not out far enough. i take it the motor is coming out the top?
Old Apr 17, 2010 | 03:09 PM
noz's Avatar
noz
im 100% sure something is holding the dam shaft i havent look really into it but i might have to remove the fork maybe????
Old Apr 17, 2010 | 04:32 PM
nope the throw out bearing and fork should not hold it up. make sure u have all the wires and stuff unhooked again. i think its going to need to come out a little more than three inches to clear the pressure plate.
Old Apr 17, 2010 | 07:43 PM
camaro_junky24's Avatar
did you pull the fork straight back it my be locked on the throw out bearing try that
Old Apr 18, 2010 | 07:13 PM
noz's Avatar
noz
how can something so small be so evil haha,, lesson to be learn before you do anything slave cylinder has to come out and slide the dam fork.. the fork was holding the throw out bearing i moved it a lil straight back the bam the fork came off like nothing before it wouldnt come out i was beating on it like crazy and nothing thanks guys........youre the man junky24
NSXTASY
Jun 9, 2012 09:17 PM
WIspartan1026
May 18, 2012 10:14 AM
adamcc91
Aug 14, 2009 10:32 PM
tspence45
Feb 7, 2008 05:51 PM
maudyZ28
Nov 9, 2007 02:58 AM
