switching from 95 3.4 v6 to 95 z28
alright so let's say both car's are both completely stock, i have a 3.4l v6 now, are the only differences in this car and the z28 is the suspension, engine, 150 mph speedo and what? i want every detail
and i see a lot of automatic z28's( =( ) so i was wondering is there anyway to install something like in a lot of newer cars have the automatic/manual option(the automatic shifter **** can move left or right to shift up or down, no clutch though =( )
also, what difference in handling will i notice if i get rims and tires(same diameter around almost)and drop the car like 1.5 inches?
They use the same rims as on the 6. Tires would be 245/50 though. Engine, PCM, wiring harness, transmission (same tranny, different bellhousing, and different input shaft), springs, gauges, fans, etc... This question has been asked a million, well now a million and one times. Search and you would find your answer. No one answered because this question is so old, and one in a billion actually go through with it after asking. There are two different options. I like option B.
Option A: http://www.tacreationsusa.com/3_4_3_8_v6_to_lt1.htm
Option B: https://camaroforums.com/m_245255/tm.htm
