Surging and ruff idle
re read your posts and changed this.... if u have replaced the ignition modual already im going to say yes. i could be wrong. was there any rust or water in the opti
Try unplugging the MAF wires. The car will run OK with the MAF unplugged, but it will force the PCM into open loop. This means that it will run on a preprogrammed mode and ignore most sensor inputs. If the surging stops with the MAF disconnected, it indicates a sensor problem, but not necessarily the MAF.
The one I removed looked good on the outside, and on the inside was some rust in the bottom on the opti. The one I put on worked fine last I used it but was covered in oil and has 130k on it. I will try running it with the maf disconnected.
Thanks
Thanks
oil is not good on a opti reader. did u try cleaning it. electric connection cleaner should work. well my opti is good. found water in the ecm/ecu its got rust in it. did not exspect that. i think i found another ecu but i wont believe till i see it. msd is fine.
