supercharger or no?
I have a Stock 96 Z28 with an automatic. i'm ready to start building up my car and I'm kinda partial to the supercharger route. I dont want a hardcore race care just somewhere around the 450-500 HP range. my question is what level of engine upgrades would I need to prep the engine to properly handle the supercharger.
Thanks |
Originally Posted by ****y_****
(Post 595394)
Thanks |
I'm not yet commited to forced induction. would it be easier to go all motor? this may be a stupid question but what are the main differences between a procharger and a supercharger?
You can get to 500 on motor alone, but it won't be cheap. Adding a turbo will be significantly less expensive, although to get to your goal you will have to build a complete powertrain.
You can use a turbo or procharger but it's easier and much cheaper to go all motor.
Intake + Exhaust + Cam + Heads + Tune You also need to upgrade the rear. A 7.5 inch 10 bolt won't cut it. |
(Post 595401)
a procharger is a brand name like vortec.
they make two type of supercharger a certrivical and i cant rember right off. but you can only put a certrivical type on a lt1 and all supercharger runs off belts i had all 4 types. my first. stock engine with vortec supercharger put down 350hp on the wheels on 8psi daily driver $2000 2nd i switch to a 72mm turbo sts kit with 8 psi and put down 370hp with 8psi $2000 daily driver third went all motor and put down 580hp on the crank on pump gas $20k some what daily driver went twin turbo front mount put down 510 to the wheels with major boost leak ay 3psi now fix pushing 12psi no numbers im going to 20-25 psi in spring. priceless some what daily driver but you can run 8 psi on a stock lt1 all day with no issues all you need is a inline pump a fuel regulator and a tune. new spark plugs. vortec sells a kit that come with everything a pump a fmu instead of a regulator and a ignition box for ignition timming so no tune is needed i ran the igition box type for my supercharger and sts kit |
Originally Posted by tt383lt1
(Post 595432)
(Post 595394)
i do need to keep it a daily driver so maybe 500 HP is a bit high. i just want enough power to beat a stock new camaro SS. I want to keep it drivable. i already planned on upgrading the whole drivetrain to handle the power. i dont want race car power just fast street car power.
| All times are GMT -5. The time now is 09:43 AM. |
