stuck lifter
stuck lifter
ok i am new to the forums and i have a question, i have a 94 z28 and it starting to make a noise when it runs, my dad says that it is a stuck lifter, how would i go by fixing that, is it to big of a fix, or is it easy???
RE: stuck lifter
well before you go speinding money listen i know this sounds cazy but it ussaly works put about half a quart of auto matic trans fluid in it it would be best if you could get the valve cover of so you get the mujoraty of the tranny fluid more where it needs to do its work but its not gonna just magicly fix it your gonna have to drive it a lil bit to get it freed up then if it dous work then just change the oil go to your local parts store they make an additve that frees stuck lifters and sunch hpoe it works for ya
[/align]
