stroker???
jus wondering what it would cost to make a 383 stroker? i see some complete engines on craigslist for about $300(i know the quality of the overall motor will matter). Im thinking i could get one and fix make it into a 383 and still have my maro to drive around will its gettin done. plus i havent done anything to my motor yet that would b a waste if i got an extra motor.
no its a stock motor. i was askin what would it cost to make it a 383. the motor is completely stock. jus askin. i wouldnt go to crazy with it if i did. maybe le3 from lloyd and whatever else to make it run
It will cost you at least a solid $3,000 just to do the short block, depending on what brand parts you buy. You can buy already built 383 short blocks in the neighborhood of $3,000 or get that cheap motor, have it properly machined, and buy all the internals to build one and that will run you about the same. On top of that, from Lloyd, a custom cam, heads (preferably LE Trickflows with a stroker) and a p&p intake is another $2,500.
