LT1/LT4 Tech 1993-1997
stall converter???
Old Apr 16, 2011 | 04:17 PM
sgtdupree's Avatar
Default stall converter???
my trans is leaking from the front. converter seal I think. since I gotta drop the trans to replace it I was thinking bout jus putting the 3200 stall in while i got it out. will it b aight even though my car is stock till I get my upgrades? it's not really a daily driver. I drive it about 100 miles a week.
Old Apr 16, 2011 | 05:48 PM
is it from under the converter cover or higher up? i had a fitting on the cooling line that was leaking on mine. really slow so it was hard to find. it looked like it could be the front seal but when i took the cover off there was no trail.
Old Apr 18, 2011 | 01:28 PM
sgtdupree's Avatar
idk. its comin from the front somewhere. i changed the pan gasket and its still leakin. its a steady drip. somebody suggested it might be from the converter seal. ima try and c where its comin from. i was jus wondering if i had to drop the tranny to fix it can i jus put in a stall converter.
Old Apr 18, 2011 | 05:41 PM
There is no such thing as a "stall converter". But, yes, you can change the stock torque converter with one of a different stall speed, while the transmission is out.
Old Apr 19, 2011 | 06:49 AM
sgtdupree's Avatar
I know that. I'm askin can I run a torque converter wit a 3200 stall wit my engine being stock? since i might have to drop the trans to fix the leak might as well put it in now.
Old Apr 19, 2011 | 06:55 AM
3200 is extreme for a stock motor. yes you can do it but depending on the converter im not so sure you will like it. i would think a trany shop would recommend a 2000 or 2500 stall for your situation.
Old Apr 19, 2011 | 07:10 AM
torque_is_good's Avatar
I've heard some of my son's friends call it that as well. I don't know if it's a Fast and Furious thing like NOS but it does grate on me when I hear it.
Old Apr 19, 2011 | 12:16 PM
sgtdupree's Avatar
llyod said i would need about a 3200 with the le2 set up. i was jus gonna put that converter in now. i wouldnt put it in if i was gonna stay stock.
FL_cracker
Apr 15, 2011 05:47 PM
tbl76camaro
Feb 8, 2011 10:06 PM
doug91rs
Mar 12, 2009 09:38 PM
partyboy8050
LS Series Tech
11
Feb 23, 2009 08:42 AM
kyphur
Jan 25, 2008 10:03 AM
