LT1/LT4 Tech 1993-1997
Sparkplug replacement HELP
Old 08-22-2006, 10:37 PM
pdpallen's Avatar
Default Sparkplug replacement HELP
I do not want to sound like a idiot, but I need advice about changing my sparkplugs. Today I had my '94 Z28 up on a lift and was able to change the drivers side plugs with relative ease. When I got to the passenger side there is no room. I managed to get one changed. Question is can the plugs be change without dropping the exaust? If so, How? Buddy of mine with much smaller hands tried and he had no luck. Any advise appreciated. Thanks in advance
Old 08-22-2006, 10:39 PM
Saint_Ali's Avatar
Default RE: Sparkplug replacement HELP
you could always pull the engine, that might be easier
no but the have an extension for spark plug wrenches that you can buy at a auto store for spark plugs that would make it easier
Old 08-24-2006, 12:29 AM
I found the easiest way is to drop the exhaust pipe from the manifold, but you also have to drop the pipe from the driver side because they are welded toghether. As an alternative you can removethe starter and AC compressor.
Old 08-25-2006, 03:56 PM
pdpallen's Avatar
Thanks for the advise. I was hoping not to have to drop the exaust but that looks to be the only way I am going to be able to get to it. Thanks again to all.
Old 08-25-2006, 09:43 PM
camarorz28's Avatar
hey guys i was thinking on changing the spark plugs to on my 94z and well is it easy dropping the exhaust???
Old 08-25-2006, 10:55 PM
pdpallen's Avatar
As far as taking off the exaust I have never done it on the camaro. However I have done it on other vehicles and it is never easy. But if you have access to a car lift I think the job will be alot easier. I will be doing it sometime next week I will let you know how it goes.
Old 08-26-2006, 08:02 PM
camarorz28's Avatar
Well i got under the car today and yeah i can see the driver side sparkplugs but I cant really see on the passanger side, I cant see any sparkplugs what would be the easiest way other than taking the car to a shop!!! LOL thanks
Old 08-28-2006, 05:17 PM
Wait till you see the labor charges.
Soundwave
03-29-2011 12:45 PM
TEXASMAN1
08-23-2008 03:17 PM
Crunchy
02-06-2008 08:24 PM
SHIVA178
01-15-2008 08:28 AM
pyrofire127
82-92 V8 Tech
12-17-2007 10:44 PM
Quick Reply: Sparkplug replacement HELP
