LT1/LT4 Tech 1993-1997
Smaller tire faster acceleration
Old Jun 25, 2009 | 08:42 PM
maroz2894's Avatar
Default Smaller tire faster acceleration
I was told you gain a little with smaller tires but lose a little top end. Whats the smallest size i could go on stock wheels?
Old Jun 25, 2009 | 09:25 PM
Yes that's true, you would gain a little. You could put rubber bands on it, but then you've entered the "rice" zone and will get disowned here!
What size tires do you have now? You can figure the math yourself, as long as you know your rear gear ratio.
Say you wanted to figure what your RPM's would be in any given gear. The formula is:
mph x trans gear ratio x rear gear ratio x 336. Then take that answer and divide your tire diameter into it.
Tirerack.com is a good source for info. Look up your tire specs, and it will give you tire diameter, width, rev's per mile, etc.
Old Jun 26, 2009 | 04:22 PM
maroz2894's Avatar
Well theyll be on the stock rims anyways so it wont look like a rice burner.. itll look original just the tires will just be small.. Anyone?
Old Jun 26, 2009 | 04:54 PM
Anyone? Did you glaze over my last sentence? ^
Maybe my response wasn't clear? You can look up Any Tire they carry and check ALL the available sizes for height comparison.
You can go with as small a diameter you want, within reason. Simple answer is you can put on the smallest tire they make to fit your wheel diameter.
Just keep ground clearance in mind, as it will be dropping the car down. And a smaller dia. tire will also give you more fender clearance. Too much fender clearance won't look good.
kocuba
Feb 3, 2012 12:43 PM
r6rider
Apr 20, 2011 07:38 AM
1971BB427
Jan 13, 2010 05:34 PM
camarocubpilot8
Mar 23, 2007 09:42 AM
93_Z28
Oct 8, 2005 01:06 AM
