Shaking
Brake fluid will absorb moisture over time and lose performance over time. It is a good idea to flush out your brake fluid and replace it every couple of years, especially if you live someplace with a lot of moisture. I personally flush and replace my brake fluid whenever I do a brake job.
Flushing out the rear end and tranny should also be done from time to time. Gives you the opportunity to check for abnormal gear wear and any possible damage. Plus, you can replace the stock gear oils with good quality synthetic stuff and that can help improve gas mileage a bit.
don't forget that the more you say you need to do under the car the longer the nap you can take while you're under there and family/friends leave you alone.
i think thats the best advice ive ever heard lol.
ok, I replaced the fuel pump and it didn't fix it... no need to do the opti yet, its the head/gasket. ill have it all done at once. I have to have it done for me, i dont have the time, but i have a guy that does motor work for my in laws, and does a damn good job. Im going to see him today. he will put it together however i want it so im putting a list together.
