ses P0301 freeze frame data HELP!!!
[align=center]
01:44.7
Short Term Fuel Trim (Bank 1)
-4.6875
01:44.8
Long Term Fuel Trim (Bank 1)
23.4375
01:44.9
Short Term Fuel Trim (Bank 2)
-3.125
01:44.9
Long Term Fuel Trim (Bank 2)
-3.125
01:45.0
Intake Manifold Absolute Pressure
4.057971014
psi
01:45.1
Engine RPM
3317.25
rpm
01:45.2
Vehicle Speed Sensor
1.875
mph
01:45.3
Ignition Timing Advance for #1 Cylinder
-42
deg
01:45.4
Intake Air Temperature
149
deg F
01:45.4
Air Flow Rate from Mass Air Flow Sensor
4.187923014
lb/min
01:45.5
Absolute Throttle Position
20
01:45.6
Commanded Secondary Air Status
OFF: Atmosphere / Off
null[/align]this is the freeze frame data from my 1996 camaro z28 it is showing a P0301 trouble code and i have already replaced the opti, plugs, plug wires, coil, 2 o2 sensors, fuel pump and fuel filter does anybody know what would be causing this??
01:44.7
-4.6875
01:44.8
23.4375
01:44.9
-3.125
01:44.9
-3.125
01:45.0
4.057971014
psi
01:45.1
Engine RPM
3317.25
rpm
01:45.2
1.875
mph
01:45.3
-42
deg
01:45.4
149
deg F
01:45.4
4.187923014
lb/min
01:45.5
20
01:45.6
RE: ses P0301 freeze frame data HELP!!!
P0301 is misfire on cylinder #1. Considering all the stuff you have replaced already, the likely suspect is a bad #1 injector, or a mechanical problem in cylinder #1. Recheck the #1 plug & plug wire, make sure the plug wire is routed properly, not burned against the exhaust or damaged and shorting out or cross firing. Do a compression test & see how cyl #1 compares to the others, get a NOID lite & verify that the #1 injector is being fired, swap #1 injector with one of the other & see if the trouble moves to a different cylinder. For proper combustion you need spark, compression, and fuel. And they need to be delivered at the proper time and quantity.
