LT1/LT4 Tech 1993-1997
serpentine belt help!
Old May 5, 2006 | 02:07 PM
akohnz's Avatar
Default serpentine belt help!
Hey, first time changing the serp. belt, does anyone have any tips or anything? Thanks to all
akohnz
Old May 5, 2006 | 07:38 PM
94Z28SHAKER's Avatar
Default RE: serpentine belt help!
Sure, the easyest way to change it is to have 2 people doing it, you will put the socket on the serpentine belt turn as to tighten, and it loosens up, hold it there, have the other person remove the belt from the alternator and it should give enough slack to remove it from the other pulleys. just make sure that you have enough room in there for the pully to swing up after the belt is off or you will jam your hand or socket in there. When putting it back on make sure you put it back exactly as the diagram says.
hope that helps, good luck, its really not that hard so just take your time.
Old May 8, 2006 | 05:29 PM
dzroc's Avatar
a tip on good horse power! add some power pulleys for about 80$ about 10-15 hp and plenty of torque.make sure you dont already have them.
Old May 8, 2006 | 06:40 PM
akohnz's Avatar
Really, I didnt know that, thanks for the tip! Do you have any ideas on where I could buy them or a good brand to buy? Thanks again
akohnz
Old May 9, 2006 | 10:11 PM
you can get them from jegs, or summit, I personally like the BBK, nice polished look, and give's noticable gains.
AzlebLyryc
Oct 31, 2011 11:07 PM
Camaro_girl1995
Jun 29, 2011 02:05 PM
GoofieJ21
Apr 13, 2009 11:03 PM
chevychick
Jan 29, 2009 10:49 PM
