LT1/LT4 Tech 1993-1997
security light
Old Sep 7, 2010 | 08:08 PM
red star's Avatar
Default security light
So after lunch today i went to start my car (96 Z28) and the security was on. it wouldnt start. the light wouldnt go away. why would this happen?
Old Sep 7, 2010 | 08:11 PM
Bessette's Avatar
Your resistor in your key is not getting detected by your system. Is it flashing?
Old Sep 7, 2010 | 08:14 PM
osduck5's Avatar
Could be several things. Take a look at this link. Usually the key going bad or the key cylinder.
http://shbox.com/1/pass_key.html
Old Sep 14, 2010 | 01:31 AM
Jmoss13's Avatar
I had the same problem and it was the tiny white wire that goes to the lock cylinder that broke. I took the column apart and tried to solder the wire back together but it kept on breaking.
If you come across the same issue I would recommend wither buying a new lock cylinder and having the car reprogrammed to that key. Or use a multi meter to measure the resistance in the key then go to radio shack and buy a resistor or series of resistors to match that resistance. Then simply wire the resistors into the connector under the dash. Car will start every time.
Old Sep 14, 2010 | 01:50 AM
or have the vats turned off at the same time have a tune done.
Socom
Nov 9, 2013 01:41 PM
canomjm1a1
Jul 11, 2013 04:18 PM
JordanN
Jan 8, 2010 10:17 AM
ranger4620
Apr 30, 2007 02:30 PM
Mr. White
Feb 28, 2006 09:06 PM
