LT1/LT4 Tech 1993-1997
Scanner / Reader 1993 Camaro Z28
Old Jul 1, 2012 | 06:32 PM
cclovern's Avatar
Default Scanner / Reader 1993 Camaro Z28
Hello to all , I am trying to find a scanner that will allow me to review the data from my engine. I had seen an Actron 9145 that said it would scan OBD 1. Can anyone recommend one that would work ?
Old Jul 1, 2012 | 07:00 PM
MKCoconuts's Avatar
Don't spend money on a scanner, it's not necessary for '93s. Buy a Haynes manual or find the code list on the web and take a paper clip and jump pins A and B (top row, last two on far right) and count the number of times the SES light flashes. For example, 1 SES light flash, pause, then 2 SES light flashes is a code 12 which will always come up when reading codes, even if the SES light isn't on. Other than that, you can pick up a scanner from your local parts store for about $30.
Old Jul 1, 2012 | 07:57 PM
cclovern's Avatar
I am trying to read the O2 sensor outputs and the map sensor reactions under throttle. I have replaced a lot of stuf to correct a rich problem and so far no luck. The MAP , TPS, OPTISPARK,Coil, EGR,fuel pressure regulator, plugs and wires are all new. The TPS tested good on throttle response.
I am going after the exhaust manifold gaskets tomorrow and possibly the intake gaskets the day after.
When I purchased the car it had a 22 code replacing the TPS sensor cleared that, and I have no other codes.
Old Jul 2, 2012 | 03:36 AM
MKCoconuts's Avatar
Might have a sticking fuel injector. Could try some fuel injector cleaner to see if that helps or have a shop clean them. If there aren't any codes present, then all your sensors are good. Even if the SES light is off, codes can be stored, so I'd double check that if you haven't all ready.
Old Jul 2, 2012 | 08:17 AM
you can get a aldl cable and software to use a your computer.
http://www.aldlcable.com/
GM OBD1 Pre-1996
Old Jul 2, 2012 | 09:07 AM
Ecidemon's Avatar
will the first link work for the 94? Also, I understand you need the $EE file, is there a place to get this without having to pay for it, or is it just specific software that needs it?
Old Jul 2, 2012 | 09:45 AM
torque_is_good's Avatar
the 9145 and it's newer replacement works on 94's and up, not the 93
I use the 9145 on my 95Z and naturally all of my OBD2 vehicles
Old Jul 2, 2012 | 09:47 AM
i have a moates setup so i havent tryed using other hardware. i know some of the guys on here have so hoping they will respond.
Old Jul 2, 2012 | 09:54 AM
Ecidemon's Avatar
I'll probably just have to break down and buy the stuff from tunercat.com.
Old Jul 2, 2012 | 10:02 AM
small handheld scanners will not show obd1 sensor readouts like they do for the obd2 systems. at least none ive seen.
