Running rich
Running rich
I am at my wits in on this car.....about ready to sell it. I took a Datamaster log of closed loop, its in open loop for 20 sec on my log here....Can someone look at this log I took today and see if theres a problem.....Oh in closed loop I get a Map code, 33 high.
closed_loop_eng.uni
closed_loop_eng.uni
Really....thats odd. I took it today. I downloaded it myself and it opened for my datamaster program. HUH...car gods dont want me to fix it..lol
High voltage from the MAP indicates high MAP which translates in low vacuum, or WOT. The PCM will set DCT 33 when it sees a High MAP when the throttle is less than 3% open. With the throttle almost closed the MAP signal should be Low (High vacuum). Could be a bad MAP sensor or bad connections or wiring to the MAP, or a vacuum leak to the sensor. The PCM looks at the map to set the fuel mixture when the engine first starts, the high map tells the PCM a lot of air is entering the engine, even though it is not possible because the throttle is almost closed, and PCM orders an overly rich mixture.
But this problem happened with the 2nd owner and he just drove it...it runs like a beast...i just dont like smelling like gas fumes everytime i drive it....and the smoke isnt bad bad till you hammer it.....
Where can I get the replacement vaccum hoses for an LT1, My local Auto parts store says they cant get em......mainly the one with the 90* on the end.
Can I pull the current tune off and save it?
orlando_trudeau@yahoo.com
06-16-2009 12:35 PM
