running hot
car just started this 2 days ago drivin runs at about 170is but stop at a light by the time its green she wil be at about 230ish and coolant drips out of the rad cap, i put a new cap on and still does it?
If I were you, I would get a new radiator cap, rent a cooling system pressure tester and pressurize the cooling system cold and see if you have any leaks, then I would completely bleed the system:
4th Gen LT1 F-body Tech Articles
Let us know how it goes.
Good luck and kill Rustanks!!!
x01660
I know that this info is for Hondas, but the info here is applicable to all liquid cooled 4 stroke engines:
Overheating: Symptoms and causes
Just from what is posted, I would check the radiator to see if it is clogged. Then check your t-stat. If not, check the oil for coolant and the coolant for oil as it might be a blown head gasket...
x01660
x01660
orlando_trudeau@yahoo.com
Jun 16, 2009 12:35 PM
