LT1/LT4 Tech 1993-1997
rod knock??
Old Apr 28, 2008 | 08:16 AM
mycarsux88's Avatar
Default rod knock??
ok so my car decided that it was going to start running very hot all of the sudden and almost overheat. so i stopped at my friends house to check it out. we found out that the coolant system just had air in it so we bled the air out and refilled the coolant. Ok so now when the car first starts the oil pressure runs a little high, around 60-70 psi until the car heats up to about operating temp, about 180 degrees which is also when the thermostat kicks on. the thermostat is brand new. also, until that 180 degree mark it makes a loud clicking noise which gets quieter as the engine heats up and it dissapears at the 180 degree mark. what would cause this??
Old Apr 28, 2008 | 07:16 PM
Default RE: rod knock??
Probably a bad valve lifter. A bearing rap would not go awayonce the enginegot warmed up. It probably would get worse as the heat causes the oil to thin out.
Old Apr 30, 2008 | 02:54 PM
mycarsux88's Avatar
how would i go about checking the lifters? i understand taking off the valve cover but how can i tell if a lifter is bad.
Old Apr 30, 2008 | 03:00 PM
mycarsux88's Avatar
btw the car only has 80,000 miles on it and is stock besides a cold air and muffler
jencamarogirl
Dec 26, 2011 11:41 AM
1998camarossclone
Apr 8, 2010 06:18 PM
SixShooterCamaro
Aug 26, 2009 08:18 AM
camarohelp
Jul 24, 2009 10:31 PM
8485Chevycowboy
Sep 3, 2007 03:41 PM
